I've just moved in to a new house and the boiler is a 2001 biasi 28s wall mounted. Before i do as suggested and replace it, i thought someone might be able to help with some advice.
The boiler stopped firing up. I took off the white metal false cover and then the actual cover, pressed reset and it fired up nicely. Put the cover back on and it went out. If i leave the cover on and wedge something in to create a small gap, it fires up. You can hear the air being sucked in through the gap i created.
Any suggestions please?
