BIASI PRISMA 24SE Start Probs
24 Sep 2009
BIASI PRISMA 24SE
Just bought a house and heating was off for ages, refilled and pressurised the system, gas is on.
The OVERHEAT THERMOSTAT had its centre pushed right in, I will change this tomorrow.
The Boiler fired up once on a quick check a few days ago for about 5 minutes, now nothing.
The green light comes on and a pump runs, but no ignition obviously.
Would it be likely that the OVERHEAT THERMOSTAT could have damaged anything else? or even shut down the system, I suspect that the previous owners had pressed the OVERHEAT THERMOSTAT in so that is u/s now.
Any help appreciated
Changed the overheat thermostat, made no difference.
The thing wont even try and ignite, reset button doesnt change anything.
Fats, the o/h stat is pushed in to be flush in the normal operating condition.
You test it by measuring its electrical conductivity.
It seems you replaced it without knowing if it was faulty or not. Surprise, surprise that has cost you about £17 and has not solved the problem.
To replace it you have opened the combustion chamber when you are obviously not gas safe qualified. On safety grounds I do not advise DIYers to change parts which involve gas or combustion parts of the boiler. In your case it was apparently not the problem anyway.
This is a very simple boiler and I could easily work out whats wrong if you were patient enough to make some simple voltage/resistance measurements.
Tony
No !
You cannot guess when mending boilers.
It has to be logical deduction based on observation and measurements.
Tony
Thanks for the advice
I will get an engineer, whats the going rate? and I am open to suggestions we are near Doncaster.
Or is Biasi still in business I could get their people out.
Biasi is one of the larger boiler suppliers after Glow-Worm, Vaillant and Worcester.
They have a network on independent service agents covering the country.
Tony
