Hi all
I have a Biasi Riva HE, it is only giving hotwater from tap. No central heating. The following things work: Pump, air fan, flow sensor(red light), timer clock. The diverter valve pin moves in and out when hot tap is open and closed. Problem is it gives no fault codes in terms of flashing lights. My wild guess is thermistors or the flowswitch/sensor that sits on the diverter valve.
I have searched the forum for solutions and not had any luck. Any suggestions would be hugely appreciated, as i am really strung up with the finances, and if it is something simple would like to deal with it myself . thnxs
