Anyone familiar with alkathene fittings and sizes?
I'm trying to replace an existing stopcock - black alkothene to 22mm copper. I've taken the existing stopcock off took it in to local Plumb centre and was given a 25mm to 22mm to replace it. When I get it back there is no way that the 25mm alkothene fitting fits. When I compare the old and new fittings the the 25mm outer part of the fitting(threaded part), almost fits in to the old fitting at the alkothene end. It's more like a 28mm copper size and I am thinking that this is what the old fitting is - 28 to 22mm.
Speaking to the PC chap it seems that both black and blue alkothene never had 28mm size but had 25mm and then 32mm. Having looked for fittings from various sources this seems to be the case. I'm looking at the moment to replace it with a 28mm to 22mm copper fitting - do not want to hack around with the existing pipes too much. Realise I may have to reduce via an alkothene fitting. Are there suitable fittings to reduce to 25mm from the larger size using a variable size fitting at one end?
