- Joined
- 12 Jun 2004
- Messages
- 2
- Reaction score
- 0
- Country
I have had two extra radiators fitted. One was fed by using the pipes for an exisiting radiator. The existing one was then fed via a T piece to an adjacent rad'. Now when I try to bleed either radiator fed from the T connector if the pump is on it sucks air in. When the pump is off the header tank pressure allows the radiator to be bled OK. The problem has come to light because one of the radiators on the T feed refuses to warm up unless the other is virtually switched off. Any ideas.
