My house is fitted with Stelrad Compact radiators - three of the upstairs radiators are hot at the bottom but cold at the top so I assume they need bleeding but there is no bleed valve like I expect to see. At the top right of each radiator is a little screw which has a white plastic head around it which I can release and remove but it doesnt seem to bleed it as there is no pressure release and it doesnt improve the heat output. Down by the temperature adjustment knob there is a little round outlet which has what looks like a traditional bleed valve in it but as its at the bottom and there is heat at the bottom I dont want to touch it as I assume it will chuck out loads of water.
What am I doing wrong? Why wont the system bleed?
Jase
Jase
