Bleeding walls
3 Apr 2005
Cleveland
I am in the process of painting our kitchen walls from yellow to white then to a colour yet to be decided.
I have noticed that a few red spots are bleeding through the white emulsion.
I'm guessing these are recent servings of ribena !! :rolleyes:
How do i stop these from bleeding through the new paint when it goes on ?
Try rubbing through the new coating and washing them off...failing that some clear knotting should do the trick
skybluescooby said:
If youve got any alkyd/oil paint in the garage or shed paint over the marks with this ( gloss will do but white undercoat is better)and leave overnight....then gently rub over it with sandpaper next day to give it a key and emulsion to your taste
Crown ....English Fire on walls.
Magnolia on ceiling.
Looks beautiful....Just done it with chrome lights.
Why white on walls first - have you got loads of it?
I shall try the tips n techniques later, thanks.
I use white as the walls are plasterboard and follwoing a coat of white matt emulsion it highlights the areas that need a tweak or fill, Then i just whack the new colour on top, Gives a clean finish
Tend to find though with knotting which is shellac based the emulsion paint put over after may show different and darker. Better with some oil based undercoat.
