I looked at my sister’s header tank today (the large 40 gallon one), as water has been flowing from the overflow. The insulating jacket was wrapped up with the ball cock (hence the overflowing) and the tank is half full with the fiberglass filling material, which has emptied out of the jacket. I figure maybe some creature has fallen into the uncovered tank and clawed the insulation into the tank while trying to get out.
I decided to drain the tank so I could clear the debris.
I turned off the main stopcock. The kitchen tap instantly lost pressure (which I expected), but so did 2 toilets and two basins. I presume they are also fed from the mains.
The bath tap flowed for say 15 to 20 seconds reducing to a trickle. I think the stirred up debris has now clogged the pipe as only a trickle still emerges after turning the stopcock back on.
My question is
how should I go about draining the tank and clearing the blockage?
My question is
