I have a small double radiator which was purchased from Wickes. Recently I had to drain the system to take some other radiators off for some decorating.
Since reinstating the system. the double radiator will only bleed in the back panel. The front is only warm for a few inches from the bottom no matter how long i leave the bleed screw open. I have tried this with the pump running and closed both to no avail.
Any suggestions as to the cause/cure?
