I have a problem with my Ideal Response 120 combi-boiler. When I turn on hot water or the CH comes on the boiler goes through it's startup sequence...
The fans starts up
The gas valve opens
The burner lights
Then within a few seconds there's a loud bang or thump inside. If you take the outer cover off you can see the inner cover move slightly when the bang occurs.
I've been told the problem relates to gas pressure. When the gas value opens, the pressure drops below the minimum 20mbar and thus the gas mix goes all to pot.
Nobody seems to know what is causing the problem. The installation is 5 months old (new house) and worked perfectly for the first 3.5 months.
I've been told numerous times that the regulator on the gas meter is faulty but it been replaced twice and still the problem occurs.
The mains pressure up to the regulator remains at a stable 25mbar. The boiler has been ispected three times by the manufacturer who claim it isn't at fault.
Does anyone have any ideas what may cause this?
Thanks.
The fans starts up
The gas valve opens
The burner lights
Thanks.
