Hello,
I have a very old Olympic Thorn boiler (38/50 model I think), that's still going strong on a gravity HW / pumped CH system.
It currently has very basic controls on the boiler itself:
a thermostat
a switch for once a day / constant / twice a day
a switch for HW / off / CH & HW
a mechanical timer with two sets of tappets
It's a very basic system, there's no valves, or other thermostats anywhere.
My understanding is that the only difference between HW and CH & HW is that with HW only, the pump is not turned on. (please can you confirm if I am correct?)
I've fitted HouseHeat RF TRVs to most of the radiators in the house so that each rooms temperature can be locally controlled by the RF Thermostat in the room (I've left the downstairs toilet and upstairs bathroom TRV-less currently).
I now have an accompanying HouseHeat product that listens to what the RF Thermostats are doing and can "control" the boiler and / or pump so as to prevent wasted energy if there is no demand for heat from the RF Thermostats. In my system, I presume that I should connect this to the pump only, as otherwise it would switch the boiler off completely and therefore the HW too?
I'd also like to replace the old mechanical time switch with a modern digital one to give more control over on/off timing through the week. Can you recommend a replacement that would work with this boiler? I presume I need one that can give the correct outputs to work with the once a day / twice a day setting on the boiler?
I've asked a couple of plumbers to quote for doing the above for me and have been told by one that it's not possible to change the timer switch and by the other that the system is too old and would need converting to fully pumped?!?!
I'd apreciate some honest advice, as I'm reasonably competent at doing this sort of work myself. Failing that, anybody covering Northants that wants to give me a quote?
Ta,
Martyn
a thermostat
Ta,
Martyn
