I have a Trianco Tro 15/19 boiler that runs off use oil.
Over the last few months the boiler occasionaly cuts out, we had a similar problem last year, initially cleaning the sensor resolved the issue, then this stopped working and we needed a new sensor.
When it custs out I press the reset button next to the burner and it fires up again and runs ok, it may cut out again after an hour of 2.
Today I put the boiler on the one hour option. Im not sure if it ran for the hour or cut out after about 1 1/2 hours I went to turn it on again, the red light ws on the panel showing it had cut out, I pressed the reset button and after about 1 minute it had cut out. I went over and there was some smoke coming out of the metal casing were the sensor is housed and next to the reset button. I took the sensor out which had quite a bit of soot on it and cleaned it and placed it back, I removed the metal cover next to the sensor about 3' by 3', inside there are what I can best describe as looking like car HT leads, these were blackened.
Any ideas as to the cause and best cause of action before phoning a plumber?
