Boiler just stopped!!!
CM . Trouble is there is that many different boilers with same model name .
very kind of you namsag but I should have asked a few more questions
If I carry on like this I will be labeled as a "part chukka"
namsag,
Yes, the pressure gauge is in a housing above the boiler. The red thingy mentioned earlier also lives in that upper housing, and has the letters W+P on it along with some other inscription that I will try to read now.
Normally, when the heat demand comes on, we hear the boiler fire up, and a constant sound that i presume is the pump. Both the firing up sound and the constant pump noise are now absent
ok, and just now, something strange happened.
As I was trying to read the inscription on the bottom of the "red thingy" (which I now suspect is a pump), the boiler came alive....... :idea: .....boiler firing up sound and all. Went on for about a minute, then stopped again.
checked the radiators......still stone cold!!! :cry:
Have a look about for a little red reset button might be up the top in housing or down at bottom of boiler behind drop down flap somewhere
JUST SAW you replied as i was, sounds like faulty pump and boiler overheating
ok thanks.
The red thing is actually some sort of reservoir (saw the words 8 litre capacity on it), and above that is the pump, i think.
well, thanks to you all for your help......seems like I am in for a big bill :cry: ...best to give up trying to find a diy solution now, i think
The bit on top of your boiler is a purpose built bit of kit for classics called a sytem kit .. The big red thing is an expansion vessel which basically takes the place of an expansion tank in loft
and could not find any reset button either.
Do you guys have any sort of idea's of costs i might be looking at to replace
1. the pump, or
2. the motorised valve (?), or
3. the gas valve?
1. the pump, or
3. the gas valve?
