Hi can someone help we've got an old Halstead Boiler which fires and runs and hot water gets quickly to the pump which appears to be working (screwdriver test) runs freely. It then slows and stops circulating with lots of banging and bumping and then the thermostat shuts off the boiler. We descaled the system last year inlcluding taking out and descaling the heat exchanger. Everything worked fine.
In September we switched on and it worked fine for two or three days then this problem began. The system has been drained and refilled half a dozen times so there is now no longer any fernox in the system but the water runs clear.
Does anyone have any ideas, has the pump had it?
Thanks in advance Mackredie
