Boiler problem
30 Apr 2009
Tyne and Wear
Hi, new here. I have a problem with my honeywell L641A1005 boiler. Recently is has stopped giving me hot water and and central heating. First noticed when the readiators weren't as hot as they should be and now im getting nothing. The pilot light is still on and the thermostat on the wall apears to be working fine. Any ideas anyone?thanks a lot.
Also, when i switch the thermostat to continuous i can hear the loud click noise as usual but it doesn't sound like its firing up.Anyone?thanks
Have you any zone vlaves on the heating system, although with a boiler of this age I would doubt it?
Also if you feel safe to, check for 240VAC at the boiler and or gas valve terminals.
If it is not there it is not a boiler problem. If it is it is probably the gas valve.
