Boiler turning on but no hot water
25 Aug 2016
Hello there.
I have a Biasi combi boiler. I woke up this morning to no hot water. The boiler would also not reset at all. I put one of my hot taps on and after 5 minutes the hot water came on and I was able to reset it.
Came home from work this evening and once again no hot water. When I turn my taps on the boiler whirrs into life as if it should be working but fails to produce the hot water.
Any clues as to what this may be?
Thank you in advance.
I think it is likely to have a fault!
But Biasi produced at least six different model ranges! Each is rather different from the others!
You might need a boiler engineer.
Tony
My boiler is saying faulty air pressure sensor. Does this make a difference?
That's fine, I just wondered if this is likely to be a serious / costly job :(
Is the Heating working ? or by boiler turning on do you mean you can hear a noise but nothing is heating up ?
Yes that's right, it's making the noise but nothing will heat up
