Bit of a two parter here so any advice that can be offered is greatly received.
Firstly, my Main Eco 30 Combi boiler has recently started making a whistling noise when there is a hot water demand, sometimes a noise can heard through the shower, additionally the hot water seems to be running a couple of degrees cooler than before, occasionally it blips back to where it should be. I recently changed a seal on the one of the water temperature sensors as the old fibre one had dropped to pieces, but I don’t see how this would have affected it though. Is it likely to be air in or around the combustion/hot water area? If so is it possible to bleed it?
Secondly, my central heating pipe work is 8mm microbore and is getting a bit tired, I would like to add another radiator and upgrade another, the plaster over one of the pipes in the wall has cracked and generally they are looking tired. Is it a difficult task to change to 15mm pipe work aside from getting access to the manifold in the floor upstairs, are there any benefits? I like the fact it’s a little more robust.
