The Boilermate had a new mixer valve fitted at the beginning of March as the radiators were getting hot each time the boiler came on to heat the stored water. The new valve seems to have failed already as after I had a shower today the radiators were on (at 12pm) and wouldnt go off unless I reduced the store temperature (to switch the boiler off).
Either the fitted valve was iffy at the time of installation or something else on the bm is faulty and causing the valve to die. This goes back to the buzzing/humming/clunking noise that I kept hearing - and has now stopped - so presumably it was the valve making the noise in the first place.
Does anyone know what might be causing the valve to prematurely fail? - pcb on bm? installed wrong? (it's 8 years old and surely cant have got through so many valves).
BG are coming again on Tuesday and I've asked BG for a quote on a whole new system. I'm giving the bm3 one more chance or its out.
Thanks,
R
Thanks,
R
