Need to get our bathroom bonded, worked out I can keep the bonding cable in zone by positioning the patress for the FCU for the pump unit for the shower inside the bathroom in Z3 instead of outside the bathroom and running the cable vertically in line with that
But now got another problem, most of the pipes enter the bathroom under the floor, the hot and cold to the sink and bath, and the CH pipes do, the shower pipes will be comming from above, and they will be 0.75m crome tails on the end of aprox 15m of PVC, so no bonding required for them (I think!... unless we have very conductive water!)
Anyway, we are going to have the floor tiled eventually, and while I might be able to bond the hot and cold at both* bath and sink, the radiator pipes can only be bonded under the floor, so I might as well get all 4 on their point of entry to the bathroom and be done with it, Now I see I have three choices:
1) Ignore rules about accessable connections and just put BS951 clamps under the floor
2) Reach further along and put the clamps on boundry with the hall, or actually under the hall... which is carpeted so more accessable than the bathroom, but its not really accesable in the way that we don't want the carpet lifting atm, so its lucky I culd put the clamps in by reaching across.
3) Solder the bonding cables, this is what I'm leading to at the moment, but a few thoughts on my mind:
a) what do you use to solder them, I'd expect a blow lamp might end up melting the insulation, and while my 18w antec is great for electronics work... , something this suitable?
b) What solder do you use, am I looking for big electrical solder, or small pluming solder?
c) Do you cover the soldering with anything?
d) How does anyone in future know its there, and the method of connection used?
*I would have to bond it at both, because if I just bonded it at one branch, sods law says someone is going to insert a piece of pvc in that branch upstream of the bond... compromising the bond to the other branch
