We have had new pipework installed which is plastic up until the pipes come through the floor boards (for each sink, radiator etc.) where they are copper pipe. What bonding is required?
Generally, only bonding is required in a bath/shower room. Metalic parts fed via plastic, where the transition happens in the room(inc under the floor), do not require bonding.
