sorry to sound simple will the pump i have work and will it effect performance if positioned above or below cylinder
If you have a positive head pump, No, it will not.
There is no difference between the actual pumps. I think what you are referring to is a "pumpset" like the one in your image which has the necessary components added (ie, expansion vessel , nrv and pressure transducers).
The component in the link I posted earlier houses the pressure switch and the nrv.
A positive head pump works on a flow rate of 2Ltrs/m minimum via a reed switch, so unless you disable the switch and fit a pressure switch instead it will not work.
Th OP is being badly advised by posters that are obviously not in the trade.
Wow ! I think that system is slightly over designed.
Why use pressure reducing valves where flow restrictor's will do ?
Do you intend to ditch the Cold water storage as 2bar mains is not ideal?
You had better store a lot of water unless your shower is fairly flow restrictive.
When you turn on the system do the street lights dim.
The combination pressure reducing valve supplied with the cylinder forms part of the Wras approval and must, be fitted
[/quote]
