Does it pump out? Put a couple of litres of water in the bottom & start a program...does the water disappear?
If yes check the supply hose is open & not kinked/twisted. pls post the full model details if you need more info "Bosch Classix" doesn't tell us much.
its a bosch classixx dishwasher type sl1501b
if u tip it on its side water comes out of the base of the unit then i try run a cycle it works fills starts to wash and then just drains and drains just took the sides off water is in the base of unit so it looks like it leeking whats the mosts common leek ?
