Bosch Dishwasher Not Draining
10 Dec 2009
Devon
I have a SGS45E08GB and it is not draining. The pump appears to be working.... I can hear it and see it rotating (with cover off). Is it the pump or something else?
Check the waste hose, they can get blocked with crud and grease/congealed fat etc.
Done all the obvious checks for crud etc. Programme seems to stick at about 25 mins on the short cycle. I have had the machine apart (even put it back together) and now know how to access all parts but am reluctant to go further without a bit of direction. Even when you think you have got all the water out, there is still about another litre in there somewhere, now on the wooden floor! Beware.
Hi, did you ever get this working again?
I also have a Bosch Exxcel SGS45E08GB that doesn't appear to be filling with water inside or draining afterwards. My initial thought would be that it's not pumping for some reason. Can anyone help?
Thanks,
Allan
The first thing your D/W should do is drain then it should fill.
Pour some water in the base and see if it comes out of the waste pipe and or you can hear the drain pump running.
After it has drained it should fill, can you hear a low humming from the rear left hand side where the fill pipe goes on.
I assume you have checked that the fill hose is not kinked and the supply tap has not been knocked to the off position.
