hi.. I've been having loads of trouble with my dishwasher lately. Started with everything coming out with a white film and tasting salty (if you didn't rinse before use) I found if I turned off the Softener it was OK but stuff wasn't cleaning very well.
I took off the side and found a large complicated plastic tank with lots of chanels through it and noticed that one section was blocked so took it out and spent over two hoors cleaning it until it was completely clear (the blocked bit had a small black plastic part inside that couldn't be seen before I cleaned it)
After putting it all back together it seemed to work fine with no more salty taste or film but the washing was still not great and the tablets often undisolved at the front of the machine.
I've now noticed ( by quickly opening the door mid wash and checking the position) that the spray arms do not always turn. Water comes out of them but they don't seem to spin which would explain the lack of cleaning and the undissolved tablets. The arms and connecting tubes are all clear as I took them all out and put a hose through them when cleaning the tank and I believe sometimes they do work, just not always.
There is plenty of water pressure although I assume this is only relevant when filling and not during the the whole wash phase...
Any help would be appreciated
