Bosch washing machine WLF 2060
18 Feb 2011
Kent
Washing machine stops at the fabric conditioner cycle, active light keeps flashing and will not complete cycle
Do you mean "WFL" 2060?
Outside the test program only 3 error codes are visible to the end user...door open, drain problem, & water supply issue. If the machine stops with the active light flashing it signals a water supply issue. How many inlet valves are there on your machine...one or two?
Hi Zipper,
have taken a look and it has 2 outlets. What do I need to do?
By definition when the program stops & the active light flashes it suggests a restricted/blocked cold fill hose, closed tap, or one of the dual inlet valves isn't functioning. However sometimes error codes can be misleading. I would check the drain pump for possible obstructions & the motor brushes for excessive wear before rushing out to buy a new valve at around £30. BTW; is the full E-number WFL2060GB/04? (look on the door sticker).
