If you have a plumber do the clean, he will probably want to use a powerflushing machine, which drives the water and chemicals round with great force. This makes the job quicker than if you did it yourself, but it will cost some hundreds of pounds.
If you are having a plumber in, get him to fit a Magnaclean for you. This is the only job that requires cutting and jointing the pipes. The device costs about £100 but you will be surprised and gratified by how much sludge it captures, even after flushing. If you have this done, and have plenty of drain valves, I think you will be able to do the chemical clean and rinse yourself. It will probably take you a matter of minutes to introduce the chemical (since you can add it through the Magnaclean) and it will probably take you a Sunday to drain and refill it after a couple of weeks, when you can add an anti-corrosion inhibitor in the same way. As you have radiators fed on drop-loop pipes you will have to drain each of them, which will take extra time but is not complicated. The Magnaclean will carry on working indefinitely, and you can open it to remove the accumulated sediment from time to time (no plumbing skills required).
p.s. make sure the filling loop is turned off and disconnected, to prevent mains water pressure geting in to the boiler.
