Bow window
17 Jan 2021
Hi, I use to be a builder for more than 20yrs, I have installed individual windows and velux windows in the past without issue, I had my son's friend to make a bow window which has arrived an it came in 4 individual windows. I was wondering if it is normal to fit each of the 4 units separately or do I need to put it all together then lift it in to place what is the norm? Is there a guide online anyone knows about or instructions to look at ? I built houses but have never done a bow window before, thanks in advance for any advice
I'm assuming this is PVC? I've fitted them both ways, I used to work with a guy would would screw a 7 seg together on the drive and carry it up a ladder with his arm through the frame and a transom resting on his shoulder, many a time it had to come back down to trim the horns a bit more
Think it's better to fit the cill in situ so it sits where the original sat, right back against the window board and fit the 2 end ones and spring the 2 middle ones in last
