Hi
We've recently purchased a property which has a large 1980's extension with a downstairs bathroom which we want to refurbish.
The external wall is 4" block, 4" gap and 4" thermolite block, the plan is to add insulation to bring that up to current building regs, we're also changing the lights, installing an extractor, along with new shower, bath, basin and toilet, skimming walls/ceiling and re-tiling - all fairly standard stuff.
However, we wanted to install wet underfloor heating (UFH) to have a warm tile floor, this is where things have become more complicated. Upon raising the current chipboard floor we were surprised to find timber battens laid over a fairly rough concrete floor (1st image). I had hoped to add some insulation and biscuit mix with UFH, but we have 50mm on one side, going to 80mm on the side nearest external wall, which isn't really enough height to work with and obviously the reason the timber battens are down.
I've broken up a small area of the concrete near the external wall (image 2), which is 4" thick and was surprised to see a void underneath the floor of approximately 4" (image 3), which may again explain the battens and can only assume the ground underneath settled over time. There is a sheet DPC in place which runs under the entire slab and I can see the internal walls which have being built on the slab have a secondary DPC in them (image 4). My plan was to break up the concrete and start afresh which will give me the height for insulation, concrete, UFH, screed etc without any build up floor height.
My question is how do I do this with the internal walls laid on the slab, should I cut around the walls with a concrete floor saw a couple of inches out and then re-incorporate this in to the upper screed layer? What about the DPC, when I cut through this with the floor saw, how will I then be able to re-instate the DPC, there will be an un-joined area?
Apologies for the long post, wanted to ensure there was sufficient information to consider.
Robert
View media item 88120
View media item 88121
View media item 88122
View media item 88123 [/img]
Robert
