My shed is made of breeze block and concrete render inside and out. Half of the shed is below ground level, and in winter soaks up the water from outside which is quite bad! The walls inside get very wet. I'm unable to dig out ground around it to do any work on the outside due to its location.
Does anyone have any idea how I can combat this? Ideally I wanted to make inside a nice dry space, where I can have a workshop. I'm thinking I need a barrier on the inisde to stop the moisture getting in - I don't mind what I use but I don't want to spend lots of money on it. Should I knock the internal cement render off and baton a lot of DPM to the walls and chipboard over it?!
I'm pretty unsure what to do with this one, as you can probably tell with my question!
Thank
Thank
