combi is it possible to fit an external programmeable stat to this boiler, i rang broag and they talked me through wiring external controls and all seemed ok at 1st. NOW customer says NO external programmer is coming up ERR.
If it is a Broag external timer then there could be a fault with the boiler. If it is an independent timer then it must be a problem within its self as the boiler could not communicate with it.
