bt openworld removal
16 Jan 2006
Newport, S Wales.
im trying to remove this from a computer as i no longer use it and it keeps trying to connect me on start up,ive looked in the add remove programme list and its not there,its also not listed under internet options connections,is there an easy way to get rid of it?
you could try search progs and find it and delete it, but it may delete some thing else :cry:
can you not set another prog as default internet connection?
tried deleting everything to do with it but it still pops up,its not even listed in the internet connections to set as a default
You may need to edit the registry.
START>RUN, type REGEDIT and click OK
Navigate to HKEY_LOCAL_MACHINE > SOFTWARE > Microsoft > Windows > CurrentVersion > Run.
Have a look to see if there is anything related to BT and delete it. I would suggest backing up the registry first.
thanks for that but i think i managed to get rid of it eventually by using one of the features of ccleaner,it was listed on a start menu so i deleted it and touch wood it hasnt popped back up
