Hi Everyone
I posted on here about a month ago to get advice about the fuse rating, cable etc for a 9.5kw Gainsborough Electric Shower.
I got the appropriate advice in terms of new RCD, Split load CB, cable etc so then got a spark in to give me an estimate.
The cost for everything would have been about £700 in view of the need for the 10mm cable probably to go on the outside wall with appropriate armour etc. (problem with noggins in pasterboard that I had not anticipated) The spark was very helpful and appreciated that it was an expensive job in the circumstances (want to sell the house, able to use the shower despite 30AMP fuse, old Mem 3 CB, only have 6mm cable etc etc) It was obvious that he was giving me official and unofficial advice and the latter was that we could probably get away with the new CB with RCD etc without the new cable which was going to be a real mother.
This was about a month ago and we decided to think about it. Shower has been used twice a day since and works fine. However, we both detected a very obvious burning/friction type smell yesterday in the bathroom and it worries me a bit.
Does it sound like the 6mm cable could be melting? Would this be the first warning before a fire? I am about to check in our loft. Is it more likely to show on the cable form the CB to the swotch or from the switch to the shower?
(I was advised that the worst thing would be that the 30AMP fuse might blow periodically)
Will probably have to downgrade the shower to 7.5 KW but would appreciate any advice.
Cheers
Tony
Cheers
Tony
