I have an electric shower in a loft conversion that looks like it belongs in a museum.
I am replacing it as part of refurb.
1) Do I need a pumped system?
It has one cold feed (15mm) which I assume is mains pressure. The pressure from the sink cold tap next to the shower it is not particulary good when on full bore. I have shower unit removed so I can give you litres/min if that helps.
Pressure in my ground floor taps is fine and I am surprised it drops so much with only a 7m difference....
2) If I need a pump do I buy a seprate pump or an integrated one? Your opinion please.
3) What pressure pump please? Any good sites to get one from?
4) What kW do you recommend? I assume the higher the faster the flow when the temp is up high?
Any help welcome.
Rgds, Scott.
Any help welcome.
Rgds, Scott.
