as i said depends if its the feed in the bottom of the f/e
or the vent pipe pumping over.
cylinder coil failed.
this will useally notice by water backfilling in from the feed pipe.
cws is useally a larger tank sitting higher than the f/e tank.
if the coil fails in the cylinder which allows dhw to pass to the system water through the pin holed coil.
so the cws will constantly empty and the f/e will constanlty fill.
due to the height of both tanks.
can also be round the other way depending on height of the tanks.
but its better to get dhw into the f/e rather than dirty system water in your dhw.
is useally due to a blockage or restriction in the pipework around the vent/feed pipe area, pump speed, vent pipe height wrong etc.
