My son has just moved into a property built approx. 25 years ago. He wants to divert a Sky cable which runs around the skirting to the other end of his lounge.
Ideally he would (with my help) like to raise the flooring and hide the cable. However he has found that the flooring is sheet board (hence why the CH pipes are visible.
Have you got any advice how you can create traps to gain access to the void underneath to push through a draw wire (or similar) and hide the cables.
Any advice welcome, thanks.
