calculating palsterboard
8 Nov 2004
i have to board a ceiling that is 3.5 mtr x 3mtr can anyone tell me how many boars i need please, i used a calcultor i found on here and it said 8 and the local builders yard said 4, im confused.
thanks
Bill
yep 4 basically depending on fixing points. they are 2.4 x 1.2 m
We always endeavour to use 900mm x 1800mm plasterboards on ceilings. 900mm 2400mm as a last resort.
Look at the centering on your timbers. 450mm (18") centres would indicate 900mm x 1800mm plasterboards and 400mm or 600mm (16"/24") centres would indicate using 900mm x 2400mm plasterboards.
Staggering the joints (essential) will mean a wee bit more wastage, so factor this in.
thanks for the reply, whichever size i use how many will i need?
16" floor joist spacing. Quite normal. Fits an 8x4ft board perfectly. The metricised sizes are almost exactly the same, apart from the name.
