How do you explain \"bus\" lines between buildings for access/alarms/computers working and not causing these problems?
Ever seen the effect of an earth potential difference on non-isolated equipment. Had that at my last place and pretty well every terminal/printer that wasn't in the office with the main system (plus a few that were) was toast - together with the main system.
Under normal conditions, these connections will work, and usually work just fine. But just lose the neutral in one building (for example, and it does happen - although rarely) and (for TN-C-S system) you may find "earth" in one building is at anything between 0 and 240V AC relative to "earth" next door.
Standard advice when taking computer connections (my area) between buildings is always to use isolation. Twisted pair ethernet has transformer isolation (though this has significant capacitive coupling), optical fibre is preferred. RS232 serial is not isolated, and as noted above tends to cause "interesting" mass failures. RS422/423 serial may or may not be isolated. Isolators for most types of connectivity are available.
I've also direct experience of dealing with the problems caused by surges imported via the phone lines. These tend not to damage a "standard" phone which is effectively not connected to anything locally - hence not affected by common mode surges. Add a fax, cordless phone, modem, whatever, that has a local power supply & earth and/or a connection to (eg) a computer which is earthed, and you suddenly find the common mode surge has somewhere to go with frequently destructive results (was a very expensive day for the customer with the fried laptop & printer). The phone and table lamp were unaffected.
EDIT:
I realise all the above has been written from the perspective of the equipment. Now suppose you import 240V AC from next door via your camera cable, and none of your AV kit is earthed (much isn't these days). You now have a TV, possibly satellite receiver, DVD player, and so on - all with their chassis and exposed connectors at 240V AC. The camera may well stop working - at which point you go groping round the back of your equipment to check the plug is in ...
If something in your setup is earthed, then you've now got 240V AC coming in via the camera cable, then via one or more interconnecting AV cables, and eventually to your earth.
