Quick question - looking at either:
Sylvania LS100 Cabinet Light T5 Tube 8w 350mm
http://www.toolstation.com/shop/Lig...net+Light+T5+Tube+8w+350mm/d220/sd3066/p24203
or:
Sylvania LS200 Cabinet Light T5 Tube 6w 250mm
http://www.toolstation.com/shop/Lig...net+Light+T5+Tube+6w+250mm/d220/sd3066/p94577
These are both mains powered and will be purchased to replace some existing (other brand) damaged units in the kitchen.
The current units are wired to the lighting circuit and are controlled by an MK grid dimmer switch (not a low voltage dimmer).
Simple one: can these HF ballasts be dimmed without any issues?
Many thanks![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
or:
Many thanks
