Can i do a temp fix on this one?
31 Aug 2005
Ok i can put my hand to most, but this one is a bit tricky, really need a proper roofer in, although the last one i had in cocked everything up so looking for a trustworthy one in dorset.
In the meantime, everytime it rains at the moment the water is running down the wall and now it's starting to attack the render, i can already feel a bubble forming where water has run into a crack in the render.
As you can or cannot see the inside is line with fibreglass but they never ran it out fully and as you can see i put a few bits of plastic with gasffer to try and make the water clear the wall but it's not working properly.
I have a collector and down pipe but still of course need some sort of fabricated tray to shove in there first? Any ideas anyone bit stumped.
Pics below.
use a torch on felt stick were you can the i would for peace of mind paint with aquamac a fibre glass paint just to make sure it wont leak wit it being the outlet hope this helps :)
