can i fit this?
19 Nov 2009
Birmingham
i have an old gas back boiler that is gravity fed for hot water and pumped for central heating. the hot water is getting 2 hot. i had a look and theres not stat on the hot water tank. i have a room stat that turns off the boiler and does the timeing. i want to know if i can fit a hot water tank stat that will turn a motorized valve so the hot water will stop heating? if i can do i need to use a three port one so i can divert the flow back to the tank or can i just put it to stop ?? the pump is alway on when the boilers running.
If the pump is always on when the boiler is running it must be inconvenient in Summer when you only want DHW.
A fully pumped system with a 3-port valve will give you much more control and might also save a bit of money on fuel.
So there's the cost of a valve and a cylinder thermostat, plus a bit of re-plumbing and re-wiring. Plenty of help here if you are into DIY.
Just do as namsag said, or convert to a 'C' Plan.
Google it.
Paul.
Upgrading to a y-plan or s-plan with a completely independent timer will drastically improve the performance, and save you money on the gasbill
Whatever you do, the vent from the boiler to the pipe above the F&E tank must remain open all the time!
