Recently we have had our old boiler, f/e tanks and the hw cylinder removed, and replaced with a WB 30cdi combi, using a corgi registered local firm.
The boiler works as well as expected, but some installation problems that occurred had me wondering if we have any recourse to compensation for damage to our property.
Basically the major problem happened when they were power-flushing the system. As the guy was going around closing and opening rad valves, one of the valve stems popped out of the valve body (his words (excuse )) causing a flood downstairs in the dining room. While they were trying to stop the flow of water nobody was keeping an eye on the power-flush machine, and this then flooded the bedroom carpet.
So now it's panic stations with three of them trying to mop up water both upstairs and down, and me getting buckets under the leaking water coming through the kitchen ceiling. I asked them why it happened, they replied because of cheap cr@ppy valves on the rads and that they weren't going to be held responsible for any damage, because if proper valves had been fitted then the power-flusher wouldn't have overflowed.
The same type of valves have been fitted to other rads on the system over a period of time as I've replaced the rads through leaks or when decorating etc. Not one of the other valves (on three new rads) popped their stems, so I'm wondering if the guy had undone the valve stem instead of opening it, because I couldn't find any part of the old valve to inspect the threads to see if they had been stripped; obviously they'd taken the valve bits with them.
I've held back from paying the remainder of the bill to see if it's worth knocking anything off it.
On another note, they also connected the flow and return pipes the opposite way to original, I'm wondering if this will have an effect on the TRV's that are fitted to a couple of rads.
I could go on about more, but I reckon this post is long enough as it is
