I want to bore a hole into a mirror to a door.
The mirrors were previously attached to wardrobes using double sided sticky tape.
I have two wardrobes each with one large heavy mirror. When the mirrors came off from the wardrobe I stuck them back with double sided sticky tape I had brought from the shop. This only lasted a couple of weeks before it came off. I tried twice using the sticky tape each time it did not work.
Now I want to drill the mirrors to a door. Firstly can one drill a hole into a mirror using a standard drill? If so which drill bit shall I use for example wood or metal or ?
Thank you in advance
