Can you identify this fuse? (small one with pic!)
19 Jan 2005
Hi everyone
I need to replace this fuse which was in the circuit board of a florescent site light. It has some writing on it but all I can manage to read is 230-250V. It's 1 cm long
Sorry about the rubbish pic and cake crumb...
SB
It's a slow blow glass fuse
Should have a rating on it, something like T2A.
The ends that are connected to the soldered end, will come off, might be a rating underneath them!
Hi there
Thanks for the quick reply. I'll have to get a magnifying glass then as the writing is SOOOO small. No writing on the board underneath the fuse (well it says FU - which I hope stands for fuse....)...
Cheers
SB
The rating should be engraved on the end caps.
Usually they say 250V, then the rating would be T (time-delayed) or F (fast acting) followed by the fuse rating followed by a letter.
I'm sure it's there, but I'm now feeling a bit depressed as I'm obviously getting so old that I can't see it with out visual aids!
Thanks for the guidance
SB
Thanks, kid, unfortunately I do.....
But you find them in SELV transformers too, amongst other things.
Did you drop your task lamp?
I dropped mine. It was a 110V one with HF control gear, and I traced the problem down to that little fuse. I replaced it and it blew straight away, so in an attempt at kill or cure I put 5 amp fuse wire in it's place. Something on the PCB was shot and it started arcing like a big scary arcy thing.
Lamp in the bin and a new one bought. :evil:
The fault-finder's last resort - fit a bigger fuse and see where the smoke comes out" ;)
My first "real" job was in a technical college, which had a load of ex-Navy Cossor oscilloscopes, mostly faulty. They had several different voltage rails in the power supply, and seemed to use each rail as a reference for the others, so I never did work out how the damn things were supposed to start up correctly. Had to use the "big fuse and trace the smoke" test quite often...
