I have the above machine with a strange issue with draining.
its an intermittent fault, it can be fine for ages, then refuse to drain for a week or so, then going back to fine again.
The pump is running (ie trying to drain) but it isn't doing anything, bizzarly if you blow down the drain pipe whilst the pump is running , you feel the pump grab hold of water and push it through the pipe (if that makes sense)
My first thoughts were a mucky drain pump, but I don't know if its a seperate drain pump or combined pump with a diverter valve
I have tried "cleaners" to flush through any crap, and it doesn't seem to have made a difference.
any ideas? I know its quite an old machine, but if it can be repaired at a small cost, I would prefer to go that route
