As above, machine shows no fault code via flashing lights, allows water into the drum as per usual, and then that is it, nothing after that.
My wife says it has worked on "hand wash" once since this fault started. Pump works as it should, so the machine will drain. Haven't yet seen the drum moving since she decided to tell me it wasn't working.
With an empty machine I've noticed any water introduced seems to drain slowly away, presumably by some siphoning action as I can't hear the pump running.
I haven't been able to tell if there has been any heating of the water going on or not yet.
Any help would be greatly appreciated.
