Can't Remove Bell Cover on Leaking Tap
22 Jun 2006
Norfolk
Hi all,
I'm trying to replace a washer on a leaky tap, I've got the handle off but can't remove the bell-shaped cover.
I've tried WD40 but it still won't budge. I've covered my spanner with a cloth but even that isn't preventing it marking the metal. The harder I try, the more I'm wrecking it.
Any ideas what I should do?
Thanks,
Kev
What would you suggest? A hair-drier or something?
Blow-torch maybe??? :LOL:
Ok - managed to undo it by wrapping elastic bands around it - gave me better grip. The tap is well corroded - I now can't undo the next bit!
Try a little heat, but keep it away from the sink. If not, remove tap, and put it in a vice to seperate 2 halves.
(re. your original problem: A 'Boa' wrench is great for undoing smooth sided items. The more you turn, the tighter it grips. Rubber strap won't damage anything either. Also available at Been & Queued. http://www.tool-up.co.uk/shop/diy/BOAOPS.html )
