Can anyone tell me if it is okay to lay carpet tiles over moisture resistant chipboard flooring(the green boards)? If so, should it be glued down to it? Also, can these green boards be attached to a concrete floor using a grab adhesive?
The correct adfhesive is called "tackifier" it allows tiles to be lifted an replace several times (but it isn`t cheap!!!!!!)
You may also get away with using carpet spray glue (just one blob) - this is the least acceptable solution however (£8 -£10 per tin)
How large is the area?
how much traffic will it get?
What sort of quality of tiles will you be using?
How good a job are looking to acheive (- i.e. how permanant)
It's in the kitchen which isn't that big. Probably 9' x 9' and there's not much traffic as it's for a person on there own so mostly just her in the house. She'll be getting tiles for around £4 each so they're not top quality but we want it looking nice.
