i had to put in a manhole, so i bought a 5t manhole cover that had a plastic outer edge.
i made a form and fixed the plastic outer part to it, then cast the concrete, i also added some colouring to match the paviours.
now the problem is that the concrete is wearing away quite quick, seems to be soft.
how is this not as robust as the precast concrete you get?
canny mind the mix i used for it.
