Well;
Cat 5 is rated to 100Mbps
Cat 5e is rated to 1000Mbps
Cat 6 is rated to 1000Mbps + with significantly lower NEXT and PSNEXT
peterduckett";p="2508512 said:Cat 5 is rated to 100Mbps
1000BASE-T was originally designed to run over CAT5 but AIUI they later discovered that some important performance parameters had never been specified so while 1000BASE-T will nearly always run over cat5 it could not be guaranteed in the worst case.
CAT5 isn't generally sold anymore though so it's not an option in consideration for a new install.
Right.Cat 5e is rated to 1000Mbps
That was my understanding, we will have to wait to see how it pans out in practice when 10GBASE-T becomes more common (afaict right now most 10 gigabit stuff is run on either fiber or SFP+ direct attatch)Cat 6 is rated to 1000Mbps with significantly lower NEXT and PSNEXT or possibly 10 Gbps over 37m where the chance of of alien interference is minimised
It's 6a not 6eCat 6e is rated to 10Gbps
Right now CAT6a seems to be about twice the price of cat6 and I suspect to actually acheive CAT6a performance is going to require very careful termination driving up installation costs.
AIUI while some cables have been marketed as CAT7 there is no such category within the standards that define the network cables we use. It remains to be seen what form a 40 gigabit ethernet over copper standard will take if one ever exists.Cat 7 is unratified to 40 Gbps and only available as STP cable
Personally I think for a normal office gigabit ethernet to the desktop will be sufficient for many years to come so there is little point installing anything higher than cat5e for links to the desktop.
1000BASE-T was originally designed to run over CAT5 but AIUI they later discovered that some important performance parameters had never been specified so while 1000BASE-T will nearly always run over cat5 it could not be guaranteed in the worst case.Cat 5 is rated to 100Mbps
Not strictly true.AIUI while some cables have been marketed as CAT7 there is no such category within the standards that define the network cables we use.
The one constant in IT is that predictions along the lines of "xxxx will always be enough" are always wrong.Personally I think for a normal office gigabit ethernet to the desktop will be sufficient for many years to come so there is little point installing anything higher than cat5e for links to the desktop.
It's an office - should be professionally done - might as well put in 6a.
Yeah, and pray tell me what you are going to do with more than 640KB in a PC?Yeah, and pray tell me what you are going to do with 10Gb to the desktop?
1Gb Ethernet is slower than a local hard disk, so is definitely reaching it's sell by date.
if you are purchasing the cable buy Cat6a.
I think you miss the point, which is that predictions along the lines of "nobody will ever need more than xxxxxx of yyyyyy" are so often wrong that you'd think intelligent people would shy away from them.I think you miss the point, which is at some point there is limit at which you don't need more of said quantity in computing for ordinary usage.
Give Microsoft bloatware a few more years...So if your computer had 640TB of RAM that would be an amount of RAM that nobody is ever going to need on a desktop. If you can come up with a use for it let me know.
So far the curve is continuing.Just because someone made a comment that is misquoted some 30 years ago and in it's misquoted form looks daft today does not mean that the curve will continue for ever.
You're right - BUT not only are the curves still very much alive and well, but they are actually still increasing in upward slope. For the forseeable future, you're therefore on very dangerous ground if you deny that considerable further increases are not only likely, but are actually virtually inevitable, before any flattening of the curves is likely to be seen.Just because someone made a comment that is misquoted some 30 years ago and in it's misquoted form looks daft today does not mean that the curve will continue for ever.
