Now I see the pics I think the guttering is suspect, any blockage behind window elevation [and yours looks quite high and likely to collect a large amount of leaf litter]will result in regular spillage over gutter or flashing causing long term damage.Any high [taller than guttering] tree's within 100metres?
Could not see any guttering to garage does it drain to rear?
Ventilation to rooms should be permanent, trickle vents to double glazed units and wall mounted vents.
